The problem is that I live in Florida. The state of Florida doesn't believe in things such as emissions, so I have to do what I do based on what will most likely lower my emissions since I have no way of testing affordably. I would really ideally like to even outdo Japan's emission requirements.
repete86 -
Florida Smog & Emission Checks https://www.dmv.org/fl-florida/smog-check.php Quote:
From my POV, the idea is to in increase MPG "within the rules" of emissions that everyone else has to comply with. You've been given a no-rules barred experimental lab. Go for it!!!!! Here's Georgia emissions requirements : Georgia Smog & Emission Checks https://www.dmv.org/ga-georgia/smog-check.php Quote:
CarloSW2 |
I think I will. Any ideas for countering the NOx emissions being created by the resistor mod though? I'm thinking that if I add a second, or maybe even two more catalytic converters behind the first one that I might be able to counter them at least partially. Again, I know very little about the mechanics of a car. Does this make sense, or am I way off?
repete86 -
I'm also not a mechanic. Other people have asked about multiple catalytic converters, so maybe someone else will pipe up on this. Question : Would a secondary catalytic converter designed for a diesel reduce lean-burn NOx????? The following is NOT an advocacy for the gizmo I am evaluating, but I do like the analysis that is presented because it first talks about stock engine emissions behavior : Emissions Analysis With Hydrogen Boost https://www.hydrogen-boost.com/August%202006.html In the above article, a "steady-throttle" is one key to low emissions in all cars. I think this would be true in the lean-burn case as well. As a gentle GasSaver driver, you may already be emphasizing behavior that reduces your emissions. Here is something else on cat-cons. I think this is a good place to find "google phrases" to look elsewhere on the net : How Catalytic Converters Work https://auto.howstuffworks.com/catalytic-converter.htm CarloSW2 |
For a Saturn, you can go as low as 110 ohms before the ECU freaks out and throws a code. I have tried 105 ohms and got a code. At 110 ohms, the IAT shows 247F. With the cold weather, I have went up to 220 ohms. This is ~200F.
You guys should be using a potentiometer instead of fixed resistors that way you can just dial in the value you want.
JanGeo-
https://home.earthlink.net/~cfg83/gas...t_vs_ohms2.jpg In the above example, in order to "dial in" IAT temperatures above 100 degrees, I would need a potentiometer that has a range of 63 (284 degrees F) to 1700 Ohms (100 degrees F). Do potentiometers come in this range? I would think that a 0-1500 ohm potentiometer would have "low granularity" at the bottom end of the dial. CarloSW2 |
I tried a potentiometer when I first started messing with the IAT mod. It was difficult to control down near the bottom of the range; very jumpy.
diamondlarry -
Hrmmmm, sounds like a kid's electronic project to me. Where's my crystal radio kit!?!?!?!?!?!? CarloSW2 |
