Box thing
How do i get that box with my mpg and the % over epa im getting to display when i post?
Hockey4mnhs -
1 - Go back to your garage entry and you will see the following at the bottom of the Garage entry (if you are logged in) : Copy and paste this text to other forums to post your stats: 2 - Below that is some text in an input box. Copy that into your clipboard. 3 - Click the UserCP Tab. You will see an Edit Signature option along the left column. Select that. 4 - Paste the text that you copied in Step 2 into the signature input box. 5 - Press the Save Signature button at the bottom. Hope this helps, CarloSW2 |
Also remember that the boxes run the 90 day average. All of your gaslog entries have no date, so they will not properly work with the signature boxes.
im on my make shift comp right no so should i fix the dates and it shoud work if i did what CarloSW2 said right?
looks to be working now!
Awsome thanks for all the help
