Old, old (pre85) EPA.
Does anyone know how to read these dos files? They're zipped, and on the EPA's site, but the notation is just odd. For instance, this is under the results for Toyota pickups
Has anyone had luck contacting Toyota about these things? |
EPA Raw Data Interp.
Cab Chassis are generally the raw cab and blank-rear frame to add the end-user's custom requirements: such as a box/van for parcels, stake-unit for farm use, a flatbed for car hauling, etc. My guess is that designation is a 1-ton model, which must have only been sold in California.
2AY may be automatic and 2MY may be the '82 manual-transmission. The difference in the double entries aren't clear, but are probably the Calif emissions and 49-state differentiations (since there are 2 in each 1/2- and 3/4-ton varieties). The 6 meaning probably means either a 6-cylinder engine or "Class-6" size, and each nubmer value is the average, specifically tested mileage of City/Hwy/Combined. If you have a 1/2-ton, CA-Emission Manual, I'd try to find out if better emissions meant a sacrifice in FE -- look at other models from the spreadsheet to see if CA-emission models in any other vehicle generally means a hit, or increase in FE. Then you can determine if the 2nd or 3rd entry is yours. Purely speculation: your EPA FE is 24-25/32-34/27-28. RH77 |
Those were all the 2WD Toyota trucks, but the only one that mentions CALIF is at the bottom. The other CALIF vehicles seem to have taken mileage hits compare to the normal 49 state vehicles, and I'm not sure what the 6 means, but most of the vehicles have it, or a 9. I'm pretty sure M/A means manual/automatic, the 2 means 2 barrel carburettor, since FI is also in that column, and the Y has something to do with yearly emissions. But those are just guesses... Actually, looking at, there were some numbers left out, and my truck must be 25/32/28, since the two Ms have
Thanks for the help! :thumbup: Although using these EPA measurements kill my percentage... I wonder how lenient the new EPA is compared to the really old EPA? Heck, my VW's supposed to get 60mpg highway, and the best I saw round trip was ~53mpg. Course this was with no attention paid to anything except driving ~45-60mph, but jeez, that's a big jump. I wish we could get an older vehicle on for one of the new tests. :D |
