Peakster -
CarloSW2 |
Back to the device, there is a thing called Impressed Current CP used on large underground equipment. It, however is based on current flow rather than the electrostatic (not electromagnetic) field I suggested. I'm still not sure where the current flow would be or across what and electric potential would be place on a car body to be effective. Just guesses. |
Back in the day 16 years ago when I worked at an airport in Guam we had those (or something that worked along the same lines) installed on our step trucks. They were rusty in 5 years.........I had always wondered if they really worked and at least I got to find out. That being said, maybe it was installed incorrectly? Hmmmmm, if your vehicle started to rust I have a feeling that would be what the company would say. I'm in a skeptical mood though. ;)
"Well, how do we know that you've even used it at all during all these years? For all we know the device has been sitting in your garage, collecting dust". |
...or they require that they do the installing if you want a warranty.
I have had personal experience for 4 years now using a Zinc block on my Honda vehicles. I used THIS Zinc block attached to the underside of my rusting CRX. It slowed the rust down to near dead stop over 2 years. I have since installed one in my wife's 2000 Protege and installed one on my 94 Civic VX after I had cut out and welded in new rear quarter panels. Although when I bought two of those blocks several years ago, they were only $7 a piece. But the copper wire that is internally cast into the block makes for a great means of connecting it to the chassis of any vehicle.
My car leaks oil, so the entire underbody is being continuously sprayed with a rust-inhibiting coating. :)
I have talked to people who would spray the underside of there vehicle with either used motor oil, or linseed oil, and that it compleatly prevented rust...
it makes sence that because rust is an electrocemical reaction that you should be able to at least slow it down with an electrical device, but how you connect it, and to what is the big question, and zinc block like that could do something... but again, I'm not sure how the whole prosess would work, but zinc does have some amazing affects on steel that are long lasting becuase of it alloying affects with the serfice of of steel. |
6 Attachment(s)
Well looky what I found parked at the university today. Not one but two rear spoilers. The top spoiler probably creates a lot of drag and increases fronal area. I'm not sure if there would be much effect with the bottom spoiler. Either way, the rear window is dirty as heck, so it must be creating lots of low pressure. The car probably has a loud exaust too:
Attachment 292 The front bumper looks ok in terms of drag (if the grille was blocked off). Too bad it's damaged on the driver's side. What's with the 'wings' on the windshield wipers? Attachment 293 On a good note, it looks like they've got good wheel spoilers for the rear tires. Attachment 294 |
The wise men around here says used motor oil is not ideal for rust protection, it contains acids and other bad stuff from the engine. Use a cheap new oil instead, and have someone with the equipment apply it, it's messy work.
There's a lot of small businesses here that do nothing but oil treatmen to cars, they spray it both inside the body/doors and on the undercarriage and it works, my father always did it and his cars has been virtually rust free despite all the salt they put on the roads in winter. Simon |
