-   -   MPG, last 2 fuel ups read blank (https://www.fuelly.com/forums/f2/mpg-last-2-fuel-ups-read-blank-412.html)
Draigflag 04-28-2010 02:42 AM
Fuel up "MPG" showing as blank for last 2 fuel ups?
My last 2 fuel read blank where the MPG's should be, the 1st one was a partial fuel up (top up) but the last one i did still shows up blank too, any ideas?
pb 04-28-2010 02:52 AM
That's expected, because once you mark a fuel-up as partial we need a full tank again to be able to calculate an MPG for an individual fuel-up. Fuelly works by calculating the difference from full, so without that full tank there's no way to get an MPG for an individual fuel-up. There's more info here and here. So the rule to keep in mind is that if you mark a tank a partial, you won't get an individual MPG rating for that tank or the next tank even if that next tank is full.
Keep in mind that all fuel-ups still contribute to your overall average MPG even if there is no individual MPG rating for a particular fuel-up.
Draigflag 04-28-2010 02:55 AM
I see, the fact was that i actually just topped up and brimmed it, so the last tank was actually measured from full in the normal way anyway. If i edit both fuel ups so they are both technically non-partial fuel ups, will they both show up then?
pb 04-28-2010 03:02 AM
Yeah, Fuelly will do what you tell it to do. If you don't fuel all the way up but don't call it a partial you'll get an MPG rating for the tank. It won't be a realistic number, but you'll get a number. Because to Fuelly it will look like you went x miles and then it only took y gallons to fill it up again.
Draigflag 04-28-2010 03:30 AM
Thanks for your help.
