-   -   Engine Additives? (https://www.fuelly.com/forums/f8/engine-additives-4149.html)
Traugbot 03-29-2007 05:37 PM
Engine Additives?
I was wondering if you guys know if there are any good additives to use for better fe
JanGeo 03-29-2007 06:14 PM
Synlube
bzipitidoo 03-29-2007 06:33 PM
From what I've been reading, light weight oil will do better than standard weight oil plus some fancy additive. I just paid $15 for 4 quarts of 5w30 "specially formulated" for engines with over 75K miles, and mean to try that out next time I change oil.
SVOboy 03-29-2007 07:29 PM
0w20 is often used, I use 5w20 for availability reasons. Otherwise, wildly varying opinions will be found, and none of them can I give you with any confidence.
Hockey4mnhs 03-29-2007 07:39 PM
were talking additives not oil rigt?
GasSavers_Ryland 03-30-2007 06:36 AM
I use Sea Foam in gas and oil a few times a year to make sure gunk is cleaned out, I'm not sure exactly what is in it, or how well it really works, altho it does seem to help, and doesn't seem to hurt anything.
I'm also used an oil system flush befor putting in full synthetic oil.
MetroMPG 03-30-2007 06:43 AM
Other than the lowest viscosity oil you can safely use, I don't think you will find a single reliable source of evidence that anything you put in your engine (or gas tank) will improve FE. (Assuming an engine in good working order.)
diamondlarry 03-30-2007 11:28 AM
My Saturn has 104K and I am using 0W20. In the last couple of thousand miles I haven't used a drop of oil nor have I heard any strange engine noises. :crossed fingers::)
JanGeo 03-30-2007 03:15 PM
MetroMPG - you seem to be the bearer of a lot of negativity lately - what's up??
