Custom Gear Machining
Thinking about this for a scooter I'm looking at buying (Honda Metropolitan). I want to gear it higher so I can increase the speed a bit and keep it from wearing out as quickly. Any ideas what this would cost?
Darin?
what years are you looking at?
Sorry, not too experienced with the machine shop rates. My only experience was with an acquaintance who runs one, and he discounted the work for the FS.
This'll be a 2003 metropolitan. Originally looking for a ruckus, that's what I have my heart set on, but I'm hoping I can get a good metro fixer-upper deal and sell that to buy the ruckus.
It is a CVT, and I am a bit confused on how it works, but I do know that there is some sort of final gear as well as a gear se, which is often swapped between the metro and ruckus. The business with the variators does confuse me also quite a bit, but I'm thinking that if a "metro gear set increases ruckus gearing by 13%" than I can get a new final or something cut for the metro without worrying about what the variators are doing. *shrug* |
Howstuffworks has a cool demo. It's just a belt that fits between two sets of pulleys, and depending on how close the pulleys are, the gear ratio on the input or output end changes.
Yeah, I've read that CVT article, but take a look at the metro/ruckus tranny: https://battlescooter.proboards27.com...ead=1162498213
check out
https://www.mrcycles.com/fiche_select.asp look under honda scooters, and 2003 ch50p, then under "driven face" it's a variable pitch pully belt drive, altho it's an extreamly commen design, it's not a very good one, it's the same design used on the honda elite, and that is slugish as hell almost compleatly due to this transmition design, but due to the laws in most states automatic transmitions are required for scooters, and mopeds, because of the fewer restrictions on operators licensing. my main reason for disliking this belt drive is that you only have a 2hp engine. |
