V12 diesel engine... Good economy?
Perkins CV12 - as used in the UK Challenger 2 tanks:
https://www.armedforces-int.com/categ...g-products.asp 1200kw!!! It is also 26.1 litre, so about 2.2 litres per cylinder :) If you had 1 cylinder from that, it would probably do for a powerful but economical car! |
A pair should even that out, or go as far as a 3 :-)
That's actually a really good amount of power for it's weight... It doesn't say it's economy - but something tells me it's pretty good for it's size and output.
my understanding that inline twins are worse vibrationwise than single cylinders. If you wnat it smooth go for 6 :D https://www.e31.net/engines_e.html |
