New to the forum..92 Protege DX
Just wanted to let you know about my beater car that gets me good gas mileage, and ask a few questions.
My car gets 41.96 MPG when driven carefully under 80% highway 20% stop and go. Believe it or not, those numbers were with 2 quarts of lucas stabilizer and 2 quarts of Valvoline High Mileage oil. The car burns oil at startup, so I suspect valve stem seals, but I dont have the time or money to fix it. I have recently switched over to Castrol 10w 30 High Mileage oil and it seems to smoke the same or less now. The air conditioning compressor locked up on me, so I can't use it :( I am probably going to pop a new one up there because driving down the highway with my windows open is killing my gas mileage, but with 100 + degree summers, and close to 100% humidity, I can't get around it since I am forced to wear businesss casual. I feel blessed that this forum does exist. Any thoughts on my car and getting better gas mileage? FYI it is the 1.8 SOHC in this car. Thanks |
Welcome to GS
Hi -- Welcome to GasSavers
Tell us a little bit more about your Protege...is it the 5-speed, how many miles? Also, what part of the world are you in? -- an approximate area is OK. (Sounds uncomfortable without the A/C). I understand with the air, though -- windows down on the highway is bad aero, but the compressor uses up the fuel -- and business casual isn't very good soaked. Problem is, you'll probably see a decrease in economy if you replace the compressor, since it will probably be used in City driving. But, there are ways to improve beyond your baseline, even with the A/C... For basics, I recommend the stickies in the General Discussion forum to get started. There's also a "Gas Mileage Contest" going on that has a good thread about some advanced technique and lessons learned. If you have any questions, we're always here to help :thumbup: Best FE, RH77 |
My wife had a '91 Protege. What a nice little sedan it was...
You are doing well with the mileage, it seems. Poke around here some and you will find some ways to do even better. |
Thanks all. I thought I posted that I was in the DC area. Whoops!
It is the 5 spd. I am pretty crafty with mechanics and since gas has gotten more expensive over the years, I have learned to stop seeing how quickly I can go down the quarter mile and do something for my wallet. Thanks for all the tips. |
