auxiliary lighting
The headlights on my car just don?t put out enough light. I need to add some driving lights to make it easier to see at night. Should I be looking at Projector beams or is there another type of lights that uses less energy?
uhh try cleaning the lenzes or getting new bulbs
headlights dim over time ya know...clean the contacts too. and please re aim them when you put in new bulbs! |
https://www.rallylights.com/hella/headlamps.asp The HID lighting uses less energy, but costs!!! Of course... |
Off topic but I couldn't resist to prove how crazy I am. Here is my car from High school and college, talk about a gas hog, actually I could get 19 on the highway, then again it was 21 feet long and weighed in at over 5500lbs.
https://www.uwgb.edu/nevermab/pic/brock-car.jpg There were eight 100w aircraft landing lights and the high beams were swapped out for 100w each as well. So with the high beams I was running over 1000w, it was nice and bright :) Each ACL had a #10 wire fed from a relay that was energized from the high beams. They were in turn fed from dual 120amp batteries in the trunk and the batteries were connected to a 120 amp alternator via #4 wire. I actually had a circuit built that would let them “bounce” from left to right, talk about attention getting ;) |
Try this place
https://www.danielsternlighting.com/ |
Cibié Oscars are great!
When I was getting schooled in upper Michigan I had 400 watts, alternators would only last a couple of years. It sounds like you fixed that in your set-up. Here is my attempt at bright lights, and early aerodynamics: https://www.gassavers.org/attachment....7&d=1170105922 |
Your Lincon has the same lights as mine When you replace the light you get awhole brandnew lens. Just get the stock replacements. I did this with all my solid light bulb cars. All headlights dull with age. Be happy, :) you get a brand new bulb and sealed lens for a fraction of the cost for the newer cars with plastic lenses. :thumbup: All my sealed beam cars were as bright as the other cars, with new lights.:cool:
