88 CRX DX Auto Transmission fill plug?
I've searched Honda-Tech but I haven't found anyone that covered the fill plug on an auto tranny.
I found the drain plug no problem. Is the fill plug on the drivers side of the tranny (when sitting in driver's seat) or on the passenger side? I think that I have found it but am not 100%. Pictures to follow shortly. |
Pictures.....
For context :
I am under the car facing forward. The part that I think is the fill plug is circled in red. https://xs315.xs.to/xs315/07194/Trann....MAY.07001.jpg https://xs315.xs.to/xs315/07194/Trann....MAY.07002.jpg |
It doesn't fill from the dipstick?
You're right, there is a dipstick on the honda autos...I forgot because the manual trannys don't have them.
I do have a dipstick.
I just figured there would be a filler hole to get the right fluid level. The only info that I could find for information regarding fluid capacity was for manual CRXs, I can't find anything for my 88 automatic. Would having too much fluid in there harm the transmission? |
Usually, you measure auto trans fluid level with the dipstick, on level ground, with the engine idling. It's not like a MT or a diff where you fill all the way up to the level of a plug.
I'm sure that having too much fluid could be harmful. |
Indeed, too much is bad, you fill a bit, let it idle, fill more, so on and so forth.
