Moving?
Hi!
What are the rules on moving in the FE challenge? Specifically, if someone moves to the other side of the world, permanently (almost certainly), and then gets another car, with the intention of bringing over their original car in the next few months? Mainly because the new car they got would be 'untested' as far as earlier FE challenge results go. |
Other side of the world, where ya moving to? |
New Zealand, most likely (still waiting to see if it will go ahead)
If I decide to stay, I will aim to build / convert my house to be fully sustainable, with a wind turbine / heat pump / solar panels / solar cells :). I would also like to buy a $50 car and convert it to electric, using solar panels mounted around my house to charge it, and use it for a lot of my commuting! |
Right - it looks like Bluey will make another cycle before going into storage!
My next car may will be a 2.0 DOHC Turbo (gasoline) Bluebird - if I can afford it and I can get the car on arrival. I will post up here when I know what is happening :) Also, the original 'Bluey' will return in the future, maybe after being shipped halfway around the world, but we will see what happens! |
OK, new car added - gaslog entries to be added later.
I want this to be my new FETC challenge car - what do I do?. I have 2 tanks already recorded, but will post these later on. Will I use the first tank as the base, compared to the second tank?. I will add the EPA (or equivalent) MPG figures later. This is my first chance to go online since arriving since gassavers.org is blocked on the proxy server at work :( |
