Transfer Vehicle to Other Fuelly User
Is there a way to transfer a vehicle to another Fuelly user?
For example, if I sell my car to user ABC and he wants all the history listed together, do I have to export the data, send the CSV file to user ABC an than he has to create a new vehicle and import the data? I can see that leading to data duplication if the original owner "retires" the vehicle instead of "removing" it from Fuelly. |
Also, one other thing ... I know it is probably much, much less common, but if you can share a car on Fuelly, why can't you share a motorcycle?
Import/export is the best way to go. We're ok with data being duplicated.
You can share a motorcycle. Is it not working for you? |
When I go to "Edit This Car" I see four buttons at the bottom of the page ... Update Car; Retire Car; Remove Car and Share Car.
When I go to "Edit This Motorcycle" I see three buttons ... Update, Retire and Remove. In the same place where I expect the Share button to appear there is this ... "Please Note: If you don't see the manufacturer of your motorcycle listed, you can request a new motorcycle maker. Also, it might take some time for your model to show up in public browsing." ... the same note that is on the "Add a Motorcycle" page. There are no other buttons or opportunities to scroll down for more page (or more cowbell). |
Thanks for the extra info. Just an oversight—the option to share should be there now.
