Gaslog
It looks like my gaslog is behind at least two,,, maybe 3 tanks. And my 90 day should have dropped off a bad tank the 21st?
Or am I seeing things? Also my last tank hand calcs show a straight up 50 mpg. The gaslog shows 49.99 mpg. Its not much. But I cant claim my first 50 mpg tank... LMAO. psy |
Be nice to see the last point on the graph too . . . or is that just on my computer that I can't see the last point on the right?
My 90 day changes about 2 days later than I think it should. I guess it takes a little patience.
the 90 day thing might be an issue with the code... I'll check it out.
as for the 49.99 vs 50, I'm unsure. there could be a rounding error somewhere in the code as well. If you enter your data using the unfinished garage2 plugin, it will definately not update immediately. The last point on the graph is an issue that has been there for a while, and will be fixed shortly. Either way, I'll check out the 90 day concern. |
man it must be nice to never have a formal change request!
just updated it. For some reason it was set to 91 days. I changed it to be 89.5 days.
I'll see what I can do about the graph tomorrow. |
Psyshack, according to my science teacher from 8th grade, you can claim a 50 mpg tank or even a 50.0 mpg tank. You just can't claim a 50.00 mpg tank. :-)
