short shift, how short?
How far short should I try to shift? My manual has a min speed per gear listed:
1st = 3 mph (idle) 2nd = 7 mph (idle) 3rd = 22 mph ~1250 rpms 4th = 33 mph ~1500 rpms 5th = 48 mph ~1750 rpms I always keep a bit above these #s. and I can still shift at 2500 or so for all shifts It doesn't like much less. Honda motors like to be revved, or well my foot likes it. Torque peak is 4500 on my engine. I saw some chart for a car doing various speeds in 5th gear, and it went down to like 38mph or so. That would definitely not make my motor happy. I am sure this was different gearing, weight etc. I bet if I somehow magically lost 500 lbs from my curb weight, that would change. My numbers for this current tank are looking good tho, and I've very rarely pushed it over 2500 rpm. Any thoughts on this? |
It depends if you are driving uphill, downhill, or on level. If you are driving on a level surface or downhill you can shift very short (just use a light throttle and you will be able to pull out of the low rpm zone).
Yup...just depends on the car and how and where you are driving. My 190e will do just fine in 4th at about 30mph if I am not attacking a hill. I did have a 1981 camaro a long time ago that would easily start in 3rd and be in 4th at 15mph...but was a LOT faster starting in 1st. :D
I can be in 5th at 20mph in the xB and did a rolling start in second at 500 rpm . . . now that was pretty low and I get concerned with the oil pressure at that speed - at least with Synlube there is lubrication even at 0 rpm but I don't like to push it that low - good minimums are 1000 rpm for slow acceleration and brisk is 1500-2000 rpm usually I am in 5th at 25 or 30 with good acceleration - 30mph is about 1500 rpm in 5th. I notice a little bogging if the engine is not fully warmed up probably due to the VVTi and igniton timing moving around if the load is too high and the rpm too low then it will skip a little so higher rpm with light throttle works more consistantly. But for hill pulls at contant throttle any low rpm will do nicely.
Be careful with short shifting in regard to trying to save gas, and increase MPG.
The mistake most make is that low RPM's mean high MPG, and this is not necessarily true. In general it is, but not always. Often, short shifting actually can use more gas and decrease MPG. Often a car needs to stay in it's "sweet spot" to get optimum MPG, which often means not shifting too short. There are many factors here, such as where peak torque is in the RPG range, the speed the car is at and in what gear. When I had my manual tranny V6 Mustang, and using a ScanGauge II, I noticed that my milage actually got worse if I short shifte, even though the engine didn't lug. And if I shifte later, it got worse too, so for your vehicle you need to find the sweet spot for a given circumstance (flat, hilly, etc). We need to divorce ourselves from the absolute that low RPG means better MPG....often it does, but there are times it does not. In my auto 2007 Yaris, if I use the gas peddle to shift short, I often see a decrease in MPG over just allowing the car to shift on it's own. Not to say this is true 100% of the time, but often it is. It took me a few weeks, but I did find the sweet spot with my Yaris and if I short shift under this sweet spot or over it, MPG decreases. Using the tach to "judge" fuel consumption is deceptive, and for this reason you need a ScanGauge II which shows Load, and GPH and other factors which will better help you fine-tune your driving technique...this is much better then relying solely on the tach, to be sure. Also and back to manual trannies, skipping gears will often not increase MPG...better to use them all to help the engine bring the car up to the required speed. |
When in creep-n-beep, I shift at idle.
One thing that the SuperMID showed me was that I wasn't getting good FE at low RPM's. Also that the throttle's effect on FE was MUCH more sensitive when the motor was lightly loaded at a low RPM than it was when it had a heavier load at a somewhat higher RPM. Its much easier to maintain an indicated 40km/l) on the SuperMID at 65mph with a injector pulse width of 4.0 than it is at 35mph with a pulse width of 2.4 (barely over the idle pulse of 2.3).
Hmm...maybe for the next fill up, I will try running at higher RPMs, but with a light throttle.
Might be interesting to see what happens. |
