Plastic Welding
Hello...been thinking about all the aero mods I can do, and comparing them with buying a body kit for my car...and I think I am going to make my own parts. Sounds more fun...maybe not any cheaper, but I can hope! :D
That said, I don't want it to look *too* frankensteinish...so I am thinking it is time to learn to weld plastic (mostly just ABS). Does anyone have any suggestions, especially on a good (inexpensive) welder and any good online tutorials to help. I have found a couple ones that seem pretty good: https://www.plasticsmag.com/welding.a...ec-00&aid=3052 https://www.plasticweldingschool.org/...le-welding.php |
here is a cheap plastic welder that I've often thought about getting;) . https://www.harborfreight.com/cpi/cta...emnumber=41592
it probably works better than a soldering iron or a magnifying glass on a sunny day:D.
Looks about like what I was also seeing on Ebay...ranging from about $40 to $80 including rods. I suppose the best way to start is just get one and start...what's the worst that can happen? :):thumbup:
I had the one from Harbor Freight. It worked fine, but I wrecked it 2x by setting it down to hard while it was still hot. It uses a heating element, sort of like a hair dryer and it gets red-white hot. I think when it's that hot the element must be extremely sensitive to any bumps. I didn't think I was being harsh in handling it, but I broke the element twice.
I don't know how well it works, I broke it before I really got a good test. It does melt the plastic, sort of similar to using an Aceylene torch. |
I've done a lot of plastic welding of polyethylene and PVC with just a heat gun with a narrowing tip on it.
I'm going to try to post an article on plastic welding in the article section. I haven't tried it yet but I have the components he recommends in the article.
John David |
Couldn't figure it out. Anyone know how to post files in adobe acrobat format?
John David |
