manual transmission damage with EOC?
Received this comment through MetroMPG.com, and not being an expert in transmission design, I thought I'd bring it here for discussion, and then point the writer here.
My initial response is - if the description of lubrication is right, then yes, the potential exists to do damage to a manual tranny from very extended ICE-off coasting. However, in practice, the length of ICE-off glides is generally short enough that it's pretty unlikely that all lubricant will be flung from the output shaft causing it to effectively run "dry" and be subject to significant increased friction. The comment seems to have been triggered by a statement I made in my ICE-on vs. ICE-off coasting experiment that 40% of my driving on that route was done ICE-off. This may have created the impression that I was coasting uninterrupted for long stretches, rather than several times per km (which "reloads" the lubrication each time). Anyway, his message to me: Quote:
Any comments on the lubrication issue from the assembled GS gearheads? |
Interesting points. I think they are valid, though I don't know at what point it would become a problem.
More times than not the final drive shaft and gear are in the lowist spot in a MT FWD tranny. Its been my experiance that this kicks more than enough lube up on the other parts to keep them lubed up. Ive never had issue with coasting a MT or AT tranny. Have been doing it for years.
Almost all tranny distruction is cause by redline gear jammers. Clutchs also take a beating in there hands. And then theres the folks that hold a car on a hill with the clutch. That will smoke a clutch and throw out bearing in nothing flat. I flat out dont worry about tranny damage. psy |
Thanks for the info, psy. It's worth noting that you haven't exactly been doing this in junkyard Metros either.
Huh... That's odd. My Bentley shows that the output shaft and input shaft are always bathed in oil, so even if the input shaft isn't spinning it's always lubed, and the spinning output shaft should be enough to lube the ring and pinion above it. I suppose if the oil level doesn't reach the output shaft by design or lack of changes, it may be trouble, but I know the transmission in the truck and rabbit are always being lubed when the wheels are spinning.
There are very few manual transmissions that will be hurt by engine off coasting. Just look at the cars being towed behind RVs they never have trouble out of the transmissions. The ring gear is big enough that it throws more than enough oil at anything important when the engine is off while the car is moving.
Agreed on starter and clutch wear. For Hondas anyhow, I disagree on his analysis.
He forgot to mention that regardless of during EOC when gears 1-5 are not turning, the countershaft and the differential are still turning. The majority of the lubrication in the transmission takes place due to the oil being slung around by the diff. This is for a few reasons - the ring gear (bolted to the diff) is the largest "gear" in the transmission. It's teeth get to the lowest point of any gear in the box, thus it is the one that slings the oil. Not only does the diff sling the oil, it is essentially the "pump" inside the box. Strategically placed narrowing channels are around the ring gear in the cast housing. While the transmission is turning, the ring gear pushes oil into these channels, which force oil to the support bearings on both shafts. It also forces oil into the hollow shafts through the oil guides and lubricates the needle bearings under the gears. While it may not sling around as much oil while EOCing, it still lubricates the components enough for no worries (in my mind). Hope that helps. :) |
Sorry,,, i didnt know metro's where so diff. than 98% of the other MT FWD trannys ever built. |
No, I wasn't saying the Metros are different - I was saying that since you're not driving a cheap car (Metro), you're obviously comfortable in your assessment of the risk of (not) damaging your vehicles.
Hope you find the answers.... psy |
