It seems everybody is going WOT
The trend from the major car makers seems to be a variable valve timing and volume, with no more need for a throttle butterfly:
Toyota Announces New Intake Valve Lift and Timing System. https://bioage.typepad.com/photos/unc...valvematic.png Excerpt: Quote:
It certainly makes sense, having variable intake lift and timing would allow the engine to be alot more efficient across a large rpm range. BMW has a similar system. I analyze product failures for a living and systems like this always make me wonder what happens when the system fails. Could you end up with a virtual wide open throttle, or is there a fail safe system that at least shuts down the engine?
It reminds me of something I really wouldn't want in a car, the Mercedes 500 SEL has a drive by wire brake system. Yikes. I don't know about you, but I like the idea that when I push my foot on the pedal that I'm actually increasing hydraulic pressure directly and not relying on a CAN based computer system directing a pump. |
This is equivalent to what is in the r18, innit?
Think so, just like BMW too.
The r18 has a throttle body butter fly. Its integrated into the control system with there tricky dicky ivtec. With attention paid to pumping loss, coupled with a variable length intake manifold.
Heres a Honda vid. https://world.honda.com/HDTV/news/2005-4050705a/ psy |
Ya, I have NO love for drive-by-wire braking.
I like the theory, but the mechanics would seem prohibitively complicated (apparently I'm wrong if they are pursuing the technology)
It's complicated because the problems (FE and emisisons) are complicated problems to solve. This is an attempt to address the requirements for a consumer product.
Chevy did something else: Displacement on Demand, or Active Fuel Management™. Probably ain't too many of these on the board. Problem is, they're putting the technology in the huge V8s and some V6s. I wonder if they'll be applying the technology to a 4-banger.
I didn't really have the time to research if there were any problems or what happens if the system fails. m |
