Where can I get non-Ethanol gas
I was wondering where I could get non-ethanol mixed gasoline in Massachusetts? Every station I have been to in my hometown has the 10% mixture sticker on the pump...
Probably nowhere. It's replaced MTBE.
you dont have just regular? we usally have a pick form three types
The pumps have a sticker on the bottom part that states the 10% Ethanol mix. It doesn't seem to be for a particular grade so I believe it is for all grades.
You will have to do some research in your state, ethanol use varies by state.
For instance here in MN all gas is E-10 except for a few stations that carry 91 octane gas with no eth. this gas is only for classic cars and motorcycle/ boats ect. That doesn't stop me from using it though.:D Some states have a choice, some have ethanol just in the 87 octane gas. |
I know Michigan gas is E10, even though some time ago our governor Granny mandated that all the stickers be removed from the pumps. I guess that's to cover the stations that didn't put the stickers on the pumps. E10 is the defacto standard. No getting away from it anymore, at least in the States.
Why avoid it?
1. because, from reading in this forum I am seeing a reduction in MPG 2. I want to see how high I can get my MPG in my Corolla |
You don't have a choice in that part of the country. Sorry.
That's what I figured.
One other topic that has me confused is fuel additives? Is there something that works both with MPG and is actually worth it $$$ wise? I've seen some posts in this forum and some say that it's a big scam and others swear by it. Can someone eluminate me? |
Although you can't test it because you can't get regular fuel. Your Toyota might be doing fine on E10. Toyota did a study and found that it did not have much effect on the small displacement motors. I looked and could not find it but here's another one that tested a Camry with no decrease if FE. |
