GMC Vandura 1994 Extended 2500 gas mileage
is there any way to improve the Vandura's mileage
currently it may be getting around or exact 14 Miles to the gallon |
That thing is a tank. Unfortunately physics are against you but there is a few things.
First, drive slower and use the brakes less. I typically drive 10 under the speed limit on the highway. Second get the torque converter locked as early as possible when accelerating. The lockup makes your engine/trans much more efficient. I'm sure there are other minor things you could do like bumping up tire pressure, removing weight, removing the roof rack/ladder, etc. |
what is a torque converter?
does it help the gas mileage a lot going 10 under? thanks. It's an automatic |
ok is it a manual or automatic?
automatic
In terms of speed, probably. If you check out the gas log for my small i4 pickup truck you can see the dip, which was due to cruising ~10+mph faster. If your truck is similar, you may approach 20mpg by cruising at 55mph assuming you get ~15mpg cruising at 65mph. Cars exhibit this too, but the speed where it manifests itself is much higher because they are more aerodynamic relative to their weight. |
https://auto.howstuffworks.com/torque-converter.htm
Okay its pretty easy to figure out when its locked or unlocked. I'm pretty sure you have a 4 speed auto. Slowly accelerate and count the shifts. From a standstill you'll be in first. Count the shifts till your in 4th. After a few seconds in 4th going a steady speed the converter will lock. You can differentiate between locked and unlocked by feel. When it locks engine speed will drop slightly. When locked the engine speed will increase steadily as you accel. When unlocked the engine speed will move up and down regardless of speed. |
