GasSavers_rGS |
06-20-2007 07:14 PM |
Originally Posted by popimp
(Post 59741)
Question about the P&G, or pulse and coast I guess. If I did the method of speeding up to 60 and using the coast function of the cruise control to drop to 55 then cruise back to 60, would this be the same as turning off the cruise then getting the speed back to 60 manually?
popimp,
Purely from a technique comparison they would be different since you're doing different things in each technique.
So with the first technique, you're basically cruise controlled at 60 mph then push the [coast] button down to 55 mph then re-engage cruise control so it automatically accelerates back up to 60 mph. Am I understanding the technique correctly? If so, based on "gut instinct" since I don't have a ScanGuage, the "automatic acceleration from 55 mph to 60 mph" is probably going to involve an RPM spike to like 2500 rpm, achieve 60mph then RPMs drop back to the appropriate RPM for 60 mph. So since it's probably going to spike, I would recommend against this technique.
Now from a pure no cruise control technique, this may result in spending too much time with your eyeballs inside the car by looking at the tachometer and the speedometer to see if the RPMs are low and the speedometer is bouncing between 55 mph and 60 mph. That would probably distract you from safety of driving by looking outside the windshield for other traffic. Increasing fuel economy and saving fuel expense is one thing, but unless you're the only car on the road, you could also "fuel efficiently collide" with another car. So like the first technique, I'd recommend against it.
What I did was to smoothly and slowly accelerate up to 55 mph then set the cruise control. Then, on the flats and gentle downhills, I would add like an extra 100~200 RPM to help nudge the speed up to 60 mph. Then once it reached 60 mph, I took my foot off the accelerator and disengaged the cruise control so that my RPMs dropped as low and fast as possible. However, at around 57 mph or so I re-engage the cruise control so that the tachometer pops up from 1500 RPM to 1800 RPM instead of spiking to like 2500 RPM had I re-engaged the cruise control at or below 55 mph. YMMV for your 2006 model. When "brain overload" happened, I just temporarily discontined pulse and gliding and just sat at 55 mph with cruise control.
I hope this helps.
