-   -   Sable Idle Speed (https://www.fuelly.com/forums/f10/sable-idle-speed-5238.html)
cbmidi 06-29-2007 09:54 PM
Sable Idle Speed
I fannally got my f/e up to 25 mph avg on the last 4 fill ups. I changed the plugs wires fuel filter, and air filter. But now the check engine light is on and the Idle seems a little high about 2500 rpm at park. I only seen it below 1000 once and that was at a stop light yesturday, but most of the time it stays at 2500 or above. oh yeah it is causing a premature shift at times.
rh77 06-30-2007 03:57 AM
Garage Entry
Hi...
I'd recommend a garage entry so we know what year the Sable is, engine, etc.
2500 is awful high -- that has to be racing! :eek: When you shift into Drive from a stop, does it lurch and take off? How about stopped at lights -- does it require a lot extra brake pedal pressure?
It should idle around 600-800 -- are you sure it's 2500???
RH77
MnFocus 06-30-2007 04:30 AM
I'd check your Throttle Position Sensor(TPS) as well as the Idle Air Controller(IAC) .
cbmidi 06-30-2007 08:08 AM
Originally Posted by rh77 (Post 61403)
Hi...
RH77
97 Mecury Sable 3.0 V6 # 3 speed trans with overdrive. Especally in the morning. I notices after it warms up it goes down alittle bit. 2000 RPM almost all the time except at traffic lights it slow to about 1000. I had Lumina z-34that was worse, I never did get that one fixed. I just want to prevent this car from gettung that bad.
MnFocus 06-30-2007 08:15 AM
Sounds like the IAC to me . I'm not a mechanic though . iirc they are less than $30 at Autozone .
