It is a celeron 500 computer so it is getting old and cheap. I see one on ebay for $200 right now but it is not a good deal. I got the computer, dock, wireless keyboard, car and ac power adapters for $350.
I guess you can say I am past the point of only spending as much on mods as I will make back in gas. I am now spending way more on mods than I can save in gas. But that is typical for me I guess, I usually start out with a kind of normal car then I get bored and I start going nuts with it :) |
All in the name of science... Nice work.
This is very interesting.
I always think, "yeah, but what about emissions..." when people start talking about modding the stock maps & A/F ratios in general. If that's a concern, I guess you could befriend one of the guys who runs an e-test dyno and test the changes to the car. Looking forward to future MPG reports. |
Very cool. Are you using an Innovate LC-1 for a wideband? Also, have you seen David Andruczyk's Megatunix software? Since you have a PC in there, you can customize guages with it.
https://www.msefi.com/viewforum.php?f...beb02ddbc25963 |
Metro, there is a dyno business in Buffalo NY that did some work on my dad's stang. I've always wondered if they could "work in reverse", tuning to make the car more fuel effiecient, other than working to squeeze out hp regardless of fuel.
megasquirt
very nice mod, who cares that you don't make the money back... experience is invaluable. Only matters if someone can do it for less, same experience. But you still did it first.
I guess when you run a car lean you get more NOx than normal so it might not be great for emissions but then again I still have not gotten around to putting a catalytic converter back on the exhaust so I guess it really doesn't change much coming out of the tailpipe.
I figure cars around here make no difference to the area's pollution since you have no idea what kind of mess they make with the emissions from coal mines around here. If you have a carbon monoxide detector in your house it will go off randomly if you are downwind of a mine. Mines around here are really bad for your health. I am using the LC-1 wideband it is a pretty nice little device. Well worth the money they want for it. I would like to take my car and dyno tune it one day and get the fuel maps dialed in perfectly but with the wideband on the car it really isn't as important to dyno tune a car as much as it used to be. I figure the car is putting out less emissions now than it was since the car is running closer to ideal. But without finding a shop with a tailpipe sniffer around here there is really no way of knowing. Also if anyone has downloaded the map I put on the car notice I put the fuel cutoff while coasting down to 1250rpm So pretty much any time I let off the gas it cuts the injectors :thumbup: There is a lot of stuff you can tweak to help mileage so once I get some miles on this setup it might be pretty impressive. |
Well not being able to leave well enough alone....
https://metroxfi.com/pics/afrtarget4.jpg I also lowered a bunch of other settings and it seems to be running ok. Now it cuts the injectors when coasting in gear at anything over 1200rpm and when decelerating but still under throttle it cuts the fuel by 50%. As well as no warmup enrichment after 30 degrees C. Car is still running smoother than it ever has before. I updated the msq file in my earlier post so download the new one and look around at it if you want. |
