just bought the scangauge!
found a place in edmonton that sells them, so ran down and picked on up.
did a bit of driving and seems to work well. have a few questions. 1. what is the standard for taking the MPG reading? is it the highest that you get on the instant setting, or the average for the whole tank, or the average for that trip-day? well that is the big question. i might have more after. |
It depends on what you are reporting. You can say...
"The highest I saw while cruising at 65 mph was..." or "My average today was..." or "My average for this tank was..." |
well i guess that i was thinking about the gas log entry.
is that all from tank to tank? as in from full to empty, or are people taking the reading from the scangauge? |
I only put fills in the gaslog. I think that that is what other people do as well... Put in the number of miles on the tank, and the number of gallons it took to fill.
I remember seeing one gaslog where the person was reporting by trip (don't recall who). "Per fill" seems to be the standard, though.
I've been through enough fills now that my readout's quite accurate, but I'm still reporting FE based on odo mileage and fill gallons, just because that's how I started my gaslog. Either should work for you though, and no calculations needed if you go with the Scangauge numbers. Just remember to jot 'em down before you hit the fill-up button! (Been there, done that. :D) Rick |
There is a group buy that you might be able to get in on. Good for $10 off. Search for "group buy" and SGII or scangauge or something like that.
