-   For Sale (https://www.fuelly.com/forums/f24/)
-   -   Kenwood KAC-PS401M (https://www.fuelly.com/forums/f24/kenwood-kac-ps401m-5399.html)
popimp 07-14-2007 10:07 AM
Kenwood KAC-PS401M
I have a Kenwood KAC-PS401M for sale. I thought I would post it here before I took it to Ebay. It's the same model as a KAC-X401M, I think they have to call it something different overseas. I am the only owner and it worked well in my Japanese 91 Civic pushing a 12" Kenwood Excelon Sub. It was purchased new in 2002. I'm asking $75. I don't have the manual but it is easily downloadable at the Kenwood UK site. I also have 10 disc Kenwood CD changer and Kewnood Excelon 12" Sub if interested. Here are the specs
Audio Section
Max Power Output (2 ½) .................................................. .................................................. 1200 W ´ 1
Rated Power Output (+B = 12.0 V)
(4 ½) .................................................. ................................200 W ´ 1 (20 Hz ~ 20 kHz, 0.05 % THD)
(2 ½) .................................................. .................................................. 400 W ´ 1 (1 kHz, 0.5 % THD)
Rated Power Output (+B = 14.4 V)
(4 ½) .................................................. ......................................300 W ´ 1 (DIN : 45324 , +B = 14.4V)
(2 ½) .................................................. .................................................. 600 W ´ 1 (1 kHz, 0.5 % THD)
Frequency Response (+ 0 , – 3 dB) .................................................. ..............................5 Hz ~ 50 kHz
Total Harmonic Distortion (Rated power)# .................................................. ..................0.002 % (1 kHz)
Sensitivity (rated output) (MAX.) .................................................. ................................................0. 2 V
Sensitivity (rated output) (MIN.) .................................................. .................................................. 5.0 V
Signal to Noise Ratio .................................................. .................................................. ..............105 dB
Input Impedance .................................................. .................................................. ......................10 k½
Damping Factor .................................................. ..................................More than 9900 (at · connect)
Low Pass Filter Frequency (24 dB/oct.) .................................................. ............50 ~ 200 Hz (variable)
Infrasonic Filter Frequency (24 dB/oct.) .................................................. ................15 / 20 / 25 / 30 Hz
Band Reject Filter Frequency .................................................. ............................40 ~ 200 Hz (variable)
# Sensitivity = Mini. , Through LPF (30 kHz)
General
Operating Voltage .................................................. ..................................12.0 V (11 ~ 16 V allowable)
Current Consumption (4 ½, +B = 12.0 V, 10 % THD) .................................................. ..................36 A
Dimensions (W ´ H ´ D) .................................................. ......................................272 ´ 64 ´ 380 mm
Weight............................................ .................................................. ...........................................7.0 kg
https://www.fuelly.com/attachments/fo...dbb72e1598.jpg
https://www.fuelly.com/attachments/fo...598d81603a.jpg
https://www.fuelly.com/attachments/fo...df0cfeba82.jpg
popimp 07-30-2007 01:53 PM
Sold on Ebay
