Why are the hybrid motors not in all cars?
The hybrid motor what I read about it is that it pulles in a gas mixure too lean to burn it then injects a vary small rich mixture at the plug the combination still leaner than what a normal engine can run . The hybrid cars have a ultra lean burning engine. I wish someone would ask the President why these engines are not in all cars and trucks! They would get better hiway miles than a hybrid can because they would be lighter in weight and cheeper to buy without the electric parts. I am screaming why are not these motors not in the new cars by now!!
Because we are not a socialist nation (yet).
Get together some investors, start a car company using this engine, and market it to people like us. Make tons of money AND help people at the same time! |
Opossum, I believe you are describing a "stratified charge" engine, still a challenge to implement IIRC:
https://en.wikipedia.org/wiki/Stratified_charge_engine |
Yikes.
Hybrid basically = a combination of features from two different types. As in a hybrid plant. Hybrid cars combine a gasoline engine plus battery motor + electric power generation driven by the spinning drivetrain. This gives some big efficiency benefits you can't get using only gasoline. You can also make a hybrid with diesel + electric or natural gas + electric or even hydrogen + electric. Same concept. The concept is to engage a large generator when braking is wanted. The generator places a huge drag on the rolling system's momentum which slows it down, capturing electrical energy in the process. Which is stored in large battery bank. The generator is also used to charge the battery at other times, depending on battery charge level and the amount of power demand from the driver. The battery bank + electric motor is used primarily in two ways. 1) When starting the car from a stop. 2) When more power is needed than the little gasoline engine can provide. This last one lets them make the hybrid with smaller engine than what would normally be used. So even when it's running on gasoline only, it's getting better mpg because the engine size is smaller. Yes it really works that way. As in, two Cadillac's, one with V8 and one with V6. The V6 will get better mpg even though the vehicles are nearly identical. The hybrid cars we have now also use some of our best FE technology that's not usually used in other vehicles. Such as overall better aero design, underbody aero treatment (though that is becoming more common), low rolling resistance tires, and Atkinson cycle engine design (a slight modification to the intake/compression/power/exhaust strokes, try look it up in Wikipedia). And more. Whatever they can think of that they think will be cost-effective for that car. Most/all of these things aren't related to hybrid technology at all. If you put them on a regular car or even on a motorcycle you'd get better fuel efficiency from that vehicle. Dig? |
Possum on brick -
CarloSW2 |
bobski -
I went and looked for the car's curb weight : Honda Stream 1.8 X (A) https://motorzone.com.sg/home/index.p...d=61&Itemid=60 Quote:
Hrmmmm. I was actually hoping for more curb weight so that the MPG would look even better. But I guess for a minivan this is pretty good. CarloSW2 |
I thought Honda had lean burn engines similar to this idea back in the 70's. If it gets good torque and decent power, I'm all for it.
