Through all the BS, still got up to 36 MPG
Just got through running the numbers on my last tank of gas, and I picked up 1 MPG, even though dealing with road rage, butt hole drivers, and some extended pedal to the metal time. I went up from 35 MPG to 36 MPG. My modifications for that tank of gas were installation of a set of Brisk spark plugs. I also noticed a smoother idle @ a lower RPM. Not sure what I will do for my next mod, as I'd like to do some aero mods, but am a little strapped for time at the moment. I may have time to try the IAT/resistor mod...
Good work! So far on my gaslog every tank has been higher and higher (except for one along time ago I think), but Im starting to reach my maximum mpg with current set-up. Just always have a goal, and eventually you'll get it...
Since you're mentioning an MPG improvement, I'm going to assume you've gotten the information suggested in your previous thread as follows: https://www.gassavers.org/showthread.php?t=4585 Now you're ready to create your very first GasLog entry. To create your GasLog Entry:
I hope this helps. |
