VX ECU, A/C delete ducting
I have one VX P07 Ecu in my possession for sale:
https://www.imagestation.com/picture/...8/e9b7db93.jpg I'm looking for $80 Shipped or B.O. Part is located in the 55316 zip code of MN. EDIT: This is a 49 states emission model, ie. 5 wire O2 and Lean Burn model. This is the last P07 ECU I have and it works great! I also have the OEM A/C Evaporator Delete Vent for any 88-91 Honda Civic/CRX. This Vent allows you to remove the A/C evaporator from under the dash and still be able to maintain HVAC functionality. https://www.imagestation.com/picture/...b/e9b6e7d5.jpg Looking for $30 or B.O. shipped for the vent piece. :D |
what year and engine was the ecu from? was it a stick or auto? thanks!
The ECU is an A00 revision which was found in the 92-93 Civic VX (will work in 94-95 VXs as well), all Civic VXs were 5 speeds.
This brings up an interesting question. Prior owner on my `92 VX screwed up the engine on it, including programming the ECU with a "performance" chip.
Is replacing the ECU probably the easiest way to fix this? I have a different engine/trans coming for it, but if the ECU is tampered with, I still might not get max FE out of it, right? I get 30-32 mpg now. |
Do you still have the rims, if so how much you want for them?
Sorry, rims are gone. I can't edit the title that is displayed in the forum. :(
I edited for you with my wizard powers.
Woot! Thanks...I wish I had super powers like yours, lol. I also wish i could afford to contribute money to this site as well. At least I can help others with knowledge though.
