-   -   a/c question (https://www.fuelly.com/forums/f8/a-c-question-5713.html)
varg 08-09-2007 02:57 PM
Just remember, don't open your windows all the way. Only a little bit. When you open them fully it creates a lot of turbulence and increases the size of the wake big time. I remember when tuft-testing my VGs when I opened my windows all the tufts of yarn went all wonky because the mass of turbulence the windows created wrapped around the car.
rvanengen 08-11-2007 08:14 AM
If you are worried about adding hot air via the heater core, you could put a manual shutoff valve on the inlet line from the engine, and ensure that no hot coolant is flowing to the heater core in the summer. :)
Bill in Houston 08-11-2007 09:04 AM
I just leave the knob turned all the way to cold...
rvanengen 08-11-2007 09:20 AM
Me too...luckily, my car has a manual button for the compressor, so I just turn the climate control all the way down, and if it gets cool enough, I can just turn the compressor off until I want it.
Bill in Houston 08-11-2007 02:13 PM
Mmm-hmm. Me too.
cheapybob 08-11-2007 09:24 PM
Run AC full cold on recirc if you really need it, and turn AC part off/on manually leaving fan on 3rd position.
AC ruins gas mileage
Hockey4mnhs 08-11-2007 10:43 PM
Or never use it and you WILL get used to it eventually
GasSavers_bobski 08-12-2007 01:07 PM
Every water-cooled car I've seen already has one. It's generally cable-operated by the temperature control just like the air mix flap, though some cars have a vacuum or motor operated valve.
