What do you monitor with your ScanGauge?
Since I've been driving for a couple of months with my ScanGauge II, I have changed what I monitor with it. This led me to wondering how others work with it.
My current standard display is: MPG GPH MPH IAT What I look at most is the top line and lately I work at keeping my GPH under some arbitrary figures based on the conditions. For example, when I'm driving at the 45 mph speed limit on a level road, I will try to keep it under 1.0 GPH. While accelerating on the level, I see if I can keep it under 1.5 GPH. This technique has helped me improve my average FE during my commutes. What do you use? |
rpm- mpg
iat- wt rpm's help me to keep steady foot on the gas pedal. I use the water temp one casue i don't trust the factory gauge in dash. i've seen 220 degree temps and needle was in same place. |
RPM / MPG
FWT / TPS The rpm is pointless since I have a tach but just never changed it on the SGII. The mpg is obvious. FWT is good to track so I know how to expect the shifting to go since it's an automatic and when it's warm it shifts much lower. TPS is good to try to see just how low I can keep the throttle to hold speed. |
Try monitoring loop, if it goes open loop when you accelerate hard then it might be an indication that enrichment has kicked in.
FYI, you want to accelerate till just before enrichment kicks in. |
I change mine around depending on what I'm doing at the moment, but most often it's:
RPM ___ MPG TPS ... where the blank is typically LOD or FWT, sometimes GPH or IAT. I have an analog tach and it works better than the ScanGauge for noting the shift from 3rd to 4th (automatic transmission) -- it's easy to see the needle drop with my peripheral vision. But my commute includes a stretch of road where the speed limit is 30MPH, and if I drive it perfectly I can keep the car in 4th and get phenomenal mileage. The ScanGauge's digital RPM readout is much better than the analog tach for keeping the RPMs above the tricky threshold around 1575-1600 RPM where the tranny wants to downshift. (That puts me at about 35MPH, so it's a delicate balancing act.) TPS because I'm trying different acceleration profiles to see which is most efficient, plus I know e.g. 10TPS reliably puts me around 1600RPM/40ishMPH/50ishMPG, etc. I like being able to accelerate to 4th gear and then quickly "lock" the throttle at what I know will be my final target. Waitin' on the next rev of firmware so I can replace one of those gauges with current average MPGs. :thumbup::D Rick |
i've always had rpm's as one of my guages. i might try tps to see if i would detect smaller changes in pedal position. |
LHK IAT
MAP LOD LHK = L/100 km, IAT in degrees C, MAP in kilopascals. The car has a tiny turbo that blows at up to 1.15 bar, which is why I monitor MAP. Sometimes I monitor coolant temperature rather than intake air, but it's fun comparing the latter to the ambient air temp shown on the smart's dashboard. |
TPS MPG
WT IAT TPS and MPG help me with my driving style and trying to improve gas mileage WT because my factory gauge is way off. IAT to monitor intercooler efficiency. |
