Jacinto's VX's First Full Tank
Had the exhaust system cleaned out at Jiffy Lube. Bunch of white smoke came pouring out of the exhaust as my friend revved the engine beyond red line. I'm told with the engine cleaner in the tank that my FE will be less this tank. Well, so far the gas gauge has budged up slightly after 74 miles. I know the car is efficient, but at some point the gas gauge should start going down, right? The VX has a puny 10.0 gallon tank. So I'm setting a modest goal of 500 miles. Posting this thread to chronicle the tank's progress.
Sidenote while I'm thinking about it about Scanguage. Are these things really accurate? If they are, I'd like to get one! Do they use the car's odometer or do they have one built in? How does it work? |
Are you a participant in the FE Challenge? Anyway there is an ongoing thread in General Fuel Economy Discussion for daily and fillup reports. That is where your FE report should be. Thanks.
SG useage is well accepted on GasSavers and there are many that have testified to it's attributes. If you do a forum search you will find comments to your question. |
I dunno, do I have to be part of a team or can I participate by myself?
This thread is in the forum you need. Forums > Community Connections > Fuel Economy Challenge. The thread you need is "Available Members or New Team Formation" Currently the 5th thread down the list. That's where team captains post when they need someone to complete a team. You definitely can post in that thread saying you're interested. People do have to drop out of a team sometimes for various reasons; you never know when a team will need you. Good Luck! |
Thee's something else called a SuperMid built and designed by a fellow named Yoshi. I don't know much about it but it should work on any fuel injected car. Needs a bit more effort to set up than the Scangauge. |
