Is three quarters of a tank really three quarters of a tank?
Well, been sipping my little VX on its first full tank. Been using googlemaps to keep track of how far I've driven. So far I've driven 184 miles in mixed driving (no interstate) with a top speed of about 60mph but a mean speed of about 45 and the gas gauge is hovering about halfway between the full line and 3/4 full. I've done a some ICE off coasting in neutral but not as much as I could and not all the time. It's a 10.0 gallon tank. What kind of mileage am I getting so far? I find that on most cars 3/4 full generally isn't 3/4 full (usally less).... What have other VX owners noticed about their gas gauges? Right now the gauge bobs from just below the Full line to just a little less than 7/8. It hasn't actually reached 3/4 yet. But even assuming it's at 3/4 full now, that means I'm looking at 736 miles or 73.6mpg for the entire tank. Is this possible? Or is my gauge lying to me? I did top off the tank about $.40 @ $2.67/gallon which is about 0.15 gallons. I think the car was pretty level when i filled it. Everything is stock on this car. Except the tires which I don't think are helping its case any.... the fronts almost look like snow tires. I guess I should wait till 1/2 tank before getting too excited. :D
Hmm 73 seems a little high for how you are driveing it would take alot more to get that, im not saying you cant with that car but im guessing your around 45-55 range. Do you have a trip botton that you can push that will count your miles? This would be alot more close to actual miles so you would know for sure.
3/4 of a tank is definitely not 3/4 of a tank. Not on any car I've owned, anyway.
I have yet to see a car with a linear gas gauge. Tanks generally have very irregular shapes to them plus the floats only go so far within them. Mine shows empty even though it has 15L/4Gal left.
Try and take note how far you have gone when you hit each major marker on the gauge and then you can gauge the tank from that. xx miles down to where you are even with the full, at xxx miles you are at the 3/4 marker, then ?, then ?... Then you'll have some reference as to how well each tank is doing. |
I don't know for your VX, but my VX cauge is completly wrong. Espacially the first half. If I fill it up completly, I might be doing 60miles and more before getting lower than the F. And I'm pretty sure its a 11.9 gallon tank we have.
The gauges aren't linear. I can usually get 100 - 120 miles before my gauge comes down to the full mark. |
Thanks guys for weighing in. It dropped drastically this morning, as if just because I had opened my mouth. It's now between 2/3 and 7/8. But, yeah, it seems the gauge is pretty unreliable. I'm now at 199.3 = miles at "3/4" tank. I'm projecting 340 miles when it has settled in on the 1/2 way mark and 580 by the time I'm not willing to drive anymore before filling up for fear of running out of gas.
Hockey4mnhs: my odometer doesn't work 1/2 the time so I have to rely on googlemaps. I think it's fairly accurate. If anything I'm driving more as it doesn't take into consideration parking lots and driveways. |
THIS post has a discussion on the civic gas gauge for reference.
