Bigger fuel tank for a civic vx ?
I would like to swap out my 10 gallon fuel tank for something a little bigger.
I can get about 420 miles per tank before I chicken out. I usually get gas around the 400-420 mark. Will the 12 gallon tank for a DX or EX work? What would be nice is if I can get a 20 gallon tank. That could possibly up my range to 850-900 miles before I freak out about running out of gas... Has anyone done this to their vx? Gary '93 Civic vx - totally stock! |
Gary |
That amount of additional fuel would add a lot of weight to the car.
lol, I was just thinking about this. I could get 1100 miles with my identical car! I think it's funny no one is willing to humor the poor guy just because it's not something that would help his FE. If anything, it might hurt it. If I knew the answer Gary I'd offer it, but I don't. But one thing you'd have to consider is that your needle is going to be on E for twice as long, and you're still gonna chicken out too early, so you probably won't double your mileage with a 20 gallon tank. If you see my reasoning Gary. Wow, that felt like a click and clack response. Nice car btw.
IIRC, gasoline weighs close to 8 lbs. a gallon. So going to a 20 gallon tank would more than double the weight of the 10 gallon tank (taking in account the extra weight of the larger tank as well). Yes, the larger tanks from the DX and Si hatchbacks of the 92-95 era will fit in the VX and would be the least amount of headache to swap. But in my eyes the ~1.9 gallons you would be able to carry wouldn't be worth it.
I think lugging extra weight around carries a bigger penalty than going to the gas station more frequently. I personally like being able to go 500+ miles on a tank of gas. |
Gary, with my '95 VX, I used to regularly trickle in 5 extra gallons of gas after the gas pump automatically stopped. I used to regularly get 700+ miles per tankful, sometimes 800 miles when I drove very economically. I don't know how it's possible to put 15 gallons in a 10 gallon tank, but I definitely did it, and it had no negative affects on anything (and no leaking fuel out of the filler neck or anywhere else).
I would need a manual to be sure, but there should be an extra gallon of two of capacity in the overflow bottle provided it has one and maybe another gallon or so in the gas tank hoses.
A 4gallon tank would be great for me. I dont see the problem with stopping to fill up and it'd eliminate 32lbs of dead weigh. |
Gary,
92 VX's have the 11.9 gallon tanks, and then Honda swapped to the 10 gallon tank. Check out this website https://www.civichatch.com/info/index.php |
