-   -   Plasma (Ignition) Booster? (https://www.fuelly.com/forums/f10/plasma-ignition-booster-5980.html)
cfg83 09-04-2007 10:20 PM
Hello -
What do you think of this? :
Plasma Booster All S-series
https://www.saturnmotorsports.com/cat...roducts_id=266
The Plasma Booster is a revolutionary ignition component to enhance your Saturns existing inductive ignition systems. Easy to install, 100% secondary current increase, 4 times spark spark energy increase for the initial spark discharge.
The fact that it says "100% secondary current" implies (to me) that it would use more juice => increase the load on the alternator => reduce MPG.
What do you think?
CarloSW2
Danronian 09-05-2007 09:58 AM
Originally Posted by cfg83 (Post 70877)
Hello -
What do you think?
CarloSW2
Looks like a gimmicy product that doesn?t do a thing.
It could be something like a MSD ignition control unit that enhances spark. Which if it is a legitimate product like that, it could work, and help MPG. But yes, it could also take more "juice" to make it work.
GasSavers_TomO 09-05-2007 10:51 AM
HERE is the sites graph of the effect the booster has on the current on a BMW.
I'm a little worried about how the device takes away current from the primary spark though.
EDIT: some good reading about the system HERE
cfg83 09-05-2007 01:33 PM
TomO -
Ok. From the above EDIT, what does this mean? :
"My research showed that you only need about 0.3 milli-joules of energy to ignite a perfect stoichiometric air-fuel mixture," Arens says. Yet modern ignition systems supply 20 to 50 milli-joules of energy, meaning there's plenty of energy available. Where that led to was studying the effect of amperage on mixture ignition, and the Plasma Booster itself.
I think he claims to use (leftover?) energy that is already in the ignition system, but I don't really understand.
I'll keep an eye on it and read up on it. If he's in San Diego, he may be worth a visit down the line.
CarloSW2
cfg83 09-05-2007 01:44 PM
Hello -
I think this is relevant to the topic :
Getting the Spark!
Crane Cams - makers of FireBall ignition systems - takes us on a quick tour of how different ignition systems work.
https://autospeed.com.au/A_0772/cms/article.html
CarloSW2
GasSavers_TomO 09-05-2007 05:46 PM
So if anyone feels the need for a test, go ahead and order me up a Summit MSD system and a plasma booster and I'll test them out on my VX. If I get good results then letting my keep the one that works well would be payment enough. ;)
