Power loss while cruising in Saturn
On one of the first days of driving my car I noticed that while cruising at 55 I would lose power for a second or two and then it would come right back. I watched the tach the next time it happened to make sure it wasn't the clutch giving out. The tach was stable the next time so I started paying attention to the engine.
This morning it did it a few times and I think that it is driving with almost no load at 55 that kicks it off. It's almost as if the fuel injectors can't squirt a small enough portion of gas so they miss and the engine loses power, if I give it a little more pedal the car comes back to life. I am going to grab some fuel injector cleaner to see if that helps any, I have seen some threads about sea foam also. Would that do the same thing? My oil change light came on so I could put some in my oil also and clean that out while I am at it. |
Clogged fuel filter not getting enough pressure to the injectors?
Hmm, didn't think about a fuel filter. But doesn't the electronic fuel pump always keep the same amount of pressure on the system? If that is the case I would think this would be a problem under acceleration from not enough fuel rather than under extremely light loads as it is.
I will look for the fuel filter anyway though, as I am quite sure it hasn't been replaced before and now is as good a time as any. |
