Set up for cooler season
Colder outside temperatures - so check your tires!
Remember - air pressure goes down approx 1 psi per each 10 deg F. drop in outside temperature. My tires were down about 2 psi from where I last set them. So yesterday I bumped them up a bit. Another quick mod - I blocked off the heater ducts to the other passenger positions. If wifey should ride with me I'll pull the foam out of the duct there. If you do this, check for rear seating area ducts too. I used foam pipe insulation since that's what I had handy. Works very well. I plan on using the heat as little as possible, but when I do use it, the duct blocks should reduce some of the heat drain on the system. |
I would like your thoughts on that. |
Yes - that is the defroster and defogger.
Vents at the windshield (front window) and heater wires in the rear window (for some cars). Yes - if your car has no control for that vent at windshield (front) then it would be good to make something to close it. I think for most cars those vents are on-off by controlls for each. I don't think we need to use a block (like foam) to close it. Of course you want to watch which vents are open and which are closed. Understand OK? What language do you speak? |
-Bob C. |
Seems it's generally agreed that a grill block is a good thing.
So having blocked my rad sufficiently to cause the fan to come on occasionally on warm days, I think I've gone as far as I dare with that. However the Volvo has a high-output heater. The a/c sucks but the heater will melt the polar ice caps. So I decided to block off the three duct outlets that don't help me stay warm (two are for rear seating area). This should allow less air through the heater core and thus less cooling effect on the coolant. I figure, any reduction in energy blown off as heat is fuel saved. Why heat the whole cabin when I just need to heat my part of it? I usually run the heater without the fan - just the normal air flow. So with fewer vents open there will be less air flow and less heat sucked off the engine. No idea yet if it helps. So far I haven't needed the heater - but I know that eventually I will. |
About blocking the heat to the back of the cabine its a good idea. I have a civic VX and I would like to had a rear cargo cover to keep that part cold, to save some heat lost. Also for the road noise too, all year long. |
