sorry, just assumed we were talking about ohc. |
Unless you are getting significantly less mileage and you know that is the cause, I would not bother changing it. If it is worn enough to replace, your engine is likely going to need to also be replaced, in which case you'd probably be better off doing the whole thing.
OHV should be OK
IIRC, OHV/Pushrod engines (mostly from GM) aren't interference-based. If the chain breaks, the engine just quits. It's one of those things that you replace when it breaks.
On my old '77 Olds 350, the timing chain broke one evening (luckily a mile from home). It just quit. When I tried to start it and it had an erratic beat to the starter. I didn't know what happened at the time (first car and all). No harm done, easy fix. Now on the Hondas, I don't take a chance on the belt -- every 80K miles with the water pump and tensioner. RH77 |
tempting offer, and now that i know you live in orlando thats not too far from palm beach, about 80 miles on the pike. what parts of orlando, and what kind of car make model year and engine is this? so far all i know is that its an under head cam olds which i have no expierence with. however it cant be much more complicated than an ohc import, which i have loads of expierence.
