-   Hybrid Vehicles (http://www.fuelly.com/forums/f35/)
-   -   DIY Chevy Avalanche conversion to parallel hybrid (http://www.fuelly.com/forums/f35/diy-chevy-avalanche-conversion-to-parallel-hybrid-6529.html)
MetroMPG 10-30-2007 05:12 PM
From the EVDL:
I am actually planning on trying this in a full size 2004 Chevy Avalanche.
I already have the batteries mounted and the charging system in place. I am
working with NetGain and will install the EMIS module due to arrive this
week. I am getting a special ADC 8: motor with a larger comm end so I can
connect it to the transmission and then attach the output shaft to a
shortened driveshaft. The motor should be here by the end of the month so
hopefully I can have the vehicle running by the end of the year.
In my 6000lb vehicle I was not able to tell any MPG drop due to the first
300lb of batteries. I now have all 12 installed so I am carry and extra 600
lbs which will grow to 800 with the motor. Time will tell if I can get a
noticeable boost in MPG. In the test done by NetGain they have seen a
25-30% improvement in in-town driving.
If interested you can see the plans to date at http://webpages.charter.net/dhrivnak/toppage1.htm
ajohnmeyer 11-13-2007 07:42 AM
Cool experiment, but what a waste. It's like trying to strap enough turbochargers and intercoolers on a V6 Mustang to get it to outrun a Mustang GT. Sure it's pretty cool once you've done it, but in the end you could just go buy the Mustang GT and have some pocket change leftover.
Silveredwings 11-13-2007 08:43 AM
For a source of generated electricity, he could hang a Prius off the back on davits. ;)
