update - '94 rusted out civic patched up a bit
well, my friend and i did some work on the car.
spent a lot of time grinding out the rust with electric drills and wire discs. we sawed away some of the panel that remained jagged. we initially tried the expanding foam as a first layer. it didn't hold up at all. we then wound up stuffing the holes with newspaper to create a frame for the fiberglass cloth to rest over and harden. basically this didn't work so well either, and the final job looks much like paper mach?. still driving this thing around. it's by far the ugliest car on the road, still, and will probably never pass inspection. i think if i were to redo it all with kitty hair it would go much better, but who knows. here's some pics: BEFORE https://dynamitetraining.com/images/longshot.jpg DURING/AFTER https://dynamitetraining.com/images/05.jpg my friend gio on the left, me on the right, proudly displaying our dollar store tools. https://dynamitetraining.com/images/06.jpg https://dynamitetraining.com/images/07.jpg https://dynamitetraining.com/images/08.jpg https://dynamitetraining.com/images/09.jpg clean as a newborn baby's butt... thanks again for all the input and hope you've all enjoyed following the glory... peace. |
Looks pretty not rusty! If only you could weld, right?
Thanks for the pics. Looks like you had a pretty good time doing it. It looks like your arch has got a partial plaster cast. Most definitely better than it was. Good job.
It sure does look....ummm...different!
Next time try getting some pieces of sheet metal, and a riveter, and a drill to make holes for the rivets. Cut the metal to the shape and form of the car, clamp them underneath the good part of the panel, drill holes for the rivets, and rivet that piece of metal on. Trim the metal at the bottom if needed, then use some Bondo to smooth out the front of the panel with some sand-paper. Doing that method, you could have the car looking stock again. But your method does hide the rust at least! |
thanks, guys.
the sheet metal idea sounds cool and possibly not too difficult. this job isn't doing anything that a finger couldn't poke right through, unfortunately. do you think i should try to put the black runner strip back on? |
Why not? If you can see a huge gap where your repaired area doesn't touch the "side skirt" then you probably want to keep it off. But who knows, it might look alright.
Congrats on doing something about it yourself!
Now you can start thinking about redoing it with the sheetmetal/rivet idea. That would allow you to have a better shape to it. It does look better than the rust that was there before. :thumbup: |
Good job on trying to make the Civic look good. I agree with everyone else. Start the sheetmetal project and keep us posted.
uh, well, i gotta hand it to you for getting it done. It ain't pretty, but it works I guess. What I would do is go to a junkyard and cut out a piece that
will fit that area from the same model year (or shape a piece of sheet metal to fit). Make sure you can overlap the metal on every edge, then tack weld it in place, then weld it up and grind down the welds. Than you spend some time to smooth it out with bondo, cheese grater, sandpaper (80-120 grit), and a DA. Prime it with etching primer on the bear metal area, then with regular primer or high build primer. More sanding (with finer grit - 220 and higher grit). Then paint with bc/cc. And finish off with wetsanding (1200-2000 grit). It'll look like my blue car (click on '91 Eclipse GSX'). If you look at the front of the rear wheel well where you did work on your civic, I did similiar work there. I think I spent the most time in that area. Amazing what bondo can do. That area was crinkled big time. Gary |
Hmmm.. I'm not a big fan of body kits, but you might be able to find a body kit that will cover up that area - one of those agressive kits that just spells RICE! :)
It looks like the rest of the car is in pretty good shape. Gary |
