Supermid-Swift Help (VSS)
I got the Supermid from Yoshi last week. I was managed to fix it with correct VSS and Injector signal (which was found by Yoshi sometimes back).
However it looks like that VSS signal is not properly detected by the Supermid unit. (No signal at all). Therefore only Injector pulse width and the total fuel usage is recordered. Is anyone who installed Supermid give me some advice? :confused: Regards CWA |
what kind of car are you installing it on? which wire(s) are you using for the VSS signal?
2 Attachment(s)
MY car is Suzuki Swift 2002-2204 Model (Japanese doemstic) with 1.3 / Auto.
I got the ECU diagram and tried on Both VSS and TP signal. Regards CWA |
FWIW, on my 98 metro the vss is the yellow and green wire going into the ECU.
