Cleaning up alloy rims
Hi:
Just received my OEM VX alloy rims I've been looking for, 1 cleaned up real well, other 3 have black crud on them (brake pad dust?) that is resisting scrubbing off. Any suggestions? I was going to try some scubbing powder, but don't want to screw up the finish....looks like clearcoat? |
Most auto parts store have a brake dust remover for wheels. Otherwise a high concentration of simple green and lots of elbow grease.
i used some kinda citrus wheel cleaner in the past, that worked pretty good but i have no idea what the name of it was.
because brake cleaner has some strong solvents in it, I would try useing a power washer first, you might even take them to a car wash and use the soapy scrub brush on the "tire" setting, then high presure hot soapy water should take most of it off, what's left should be able to be removed with a scouring pad and some brake cleaner.
I have the same issue with the "baked-on" brake dust on my VX wheels. For mine the damage has gone through the clearcoat and paint, so there is nothing that will bring them back to their OEM beauty without some stripping of the wheels and some new paint.
I might do a how-to on this very topic since I'll be picking up a set of painted black VX wheels tomorrow for winter tires. (For a great deal of $125 with good tires! YAYA) |
Guys, please try some brillo pads. This stuff works wonders and will get all of that black crud out of there. I went to the dollar store and bought a the cheap brillo pads, not the name brand BRILLO ones. When I picked up my VX, the wheels had all of the black dust on them and one wheel was almost completely black on the inside. I started off using a sponge with the green hard side. That worked a little but didn't get all of it. I tried the pad and the wheels look new. No damage Try it
Thanks....I already tried the sponge, with the same results. Will try generic "Brillo" pads and report on results.
I'll try the brillo pads on mine, though I think I tried them before on my wheels, and it didn't do thing...
You didn't use any elbow grease Dan! lol
After trying an "all wheels" cleaner with limited success, I bought an etching wheel cleaner for non-clearcoated wheels. Along with a stiff bristle brush, it worked great, removed all unsightly brake dust residue and didn't damage the clearcoat. YMMV
Doug |
