-   General Fuel Topics (http://www.fuelly.com/forums/f8/)
-   -   Just wondering about adding a bit of B100 to RUG (Regular unleaded)? (http://www.fuelly.com/forums/f8/just-wondering-about-adding-a-bit-of-b100-to-rug-regular-unleaded-6831.html)
DarbyWalters 11-21-2007 04:48 PM
Driving home tonight I was thinking...what could be the advantages to adding a small percentage of B100 to RUG for FE? If it was kept at 2.5-5% I don't think it would cause and "running problems". The BioDiesel would also act as a lubricator. Lastly, the extra BTUs might do interesting things to the mix. Not to mention the possible reduced COs. Has anyone tried it?
theclencher 11-21-2007 05:35 PM
http://www.gassavers.org/showthread....hlight=gas+mix
ryland pondered about something similar
skewbe 11-21-2007 06:41 PM
Hadn't seen that before, thats pretty cool.
GasSavers_Dust 11-21-2007 07:10 PM
Check your oil and look for polymerization. A guy on biodiesel.infopop tried it and it leaked passed his rings on start up and thickened his oil in 1000 miles. I guess if you start and warmup on pure gas it wouldn't be a problem, but you are defeating the purpose.
GasSavers_Ryland 11-21-2007 07:48 PM
I ran out of Biodiesel befor I could to enough testing, for the most part what I started out doing was checking to see if the B100 mixed with gasoline, would foul up spark plugs, or o2 sensors, as far as I could tell with the few hundred miles that I put on my 4 stroke motorcycle, it had no negative affects, it seemed to burn compleatly, it didn't detract from the power of the 12.5hp engine (part of why I chose a small motorcycle to test, a drop in power would show), but I wasn't able to proove that my gas mileage changed, up or down, after taking in to acount the amount of B100 that I added, other then the fact that the B100 was acting as a direct replacment for the gasoline.
If you don't want to go back and re-read my old posts, I was running a 10:1 mix in a honda cb125, altho a 5:1 mix worked "ok" I think my motorcycle engine runs to fast (10,000rpm) for a compleat burn to happen.
Otistheminivan 11-22-2007 04:34 AM
Ryland is that % of mic correct? I run 2 stroke snowmobiles that make in excess of 300Hp without NOS, with NOS 350-400hp and we run mixtures of 40:1. 5-10:1 that thing would be a smoke machine and that would realy screw something up on a FI car.
John
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
