Yeah I saw the mythbusters test - big V6 at 60mph dyno test which is NOT where the acetone helps the fuel burn better. It helps more at lower throttle openings in engines with smaller amounts of fuel being injected where the fuel needs more help to vaporize not the gas guzzling american poorly built V6 engines that just dump fuel in. I have run with and without it and see an improvement with it as well as better idle and smoother throttle response. Would have liked to have used it without the ethanol in the gas though to really see how much it could have helped.
I tried 2 ounces of acetone in a 13 gallon tank and got nothing more out of it than the tank before. Oh and that was with an ecotec 2.2 4 cylinder. |
Like I said it makes a big difference because it helps the fuel to vaporize better and if you are dumping a lot of fuel into the intake it will not help because the injectors are working well at that high volume of fuel . . . it's when they are only spitting out a little bit of fuel that it becomes more critical that the fuel be vaporized better so that it can ignite. It can be at the right total ratio but the fuel may not be blended very well with the air when only a little bit of fuel is injected. Which is what happens when you have a vehicle that is running slow at 40-50 mpg vs 20mpg at 60mph. 2oz in 13 gallons is too little an amount - you need 4 or 5 oz with that much fuel to get the peak benefit - too little or too much reduces the benefit to nothing. As far as V6 engines go I have a friend that I ran the scangauge on and saw 0.5gph at idle compared to my .1gph at idle in my Scion 1.5 liter 4 so yeah they suck gas like crazy 5 times what mine does.
Gee, its a no brainer that a larger displacement engine will require more fuel than a smaller engine. Also, the amount of fuel being sprayed at the injectors is still going to be proportional to the incoming air. Atomization was a problem with carbs but not so much with modern fuel injection. |
Some have tested isopropyl alcohol at 4-5 oz per 10 G to work with the ethanol blended in gas. Must be used with a lube such as 3 oz MMoil or maybe 5 oz WD40 per 10 G though.
Some areas have 90% isopropyl in drug stores I guess. |
Yeow I don't know about only 90% that still leaves 10% water not a good thing to be adding to the tank! Drug stores sell 70% and 90% all the time. I hear WD40 is a big NO NO to add to the fuel system also - contains stuff that either doesn't burn right or attacks plastic in the fuel system.
There is already water in your ethanol laced gas? Some even use 70% isopropyl...so they claim...to "remove" water from gas in winter. |
I guess the real test would be to add some to gasoline and see what happens - if it separates out into a white cloud or droplets of water at the bottom then it's not a good idea.
The other thing to do when testing acetone is use different concentrations because all engines are NOT built the same, do NOT always run 14.7:1 mix ratio and do not have exactly the same fuel pressure, injectors, port aerodynamics, are not always running the exact same blend of gas, and most importantly are never in the exact same state of cleanlyness, repair, or operation.
