A shot with a mix...
Ok, first, a big thanks to ZugyNA...
Some background, I read through Daniel's site, and it was really interesting, but nothing particularly ground breaking. Until he started to talk about how the plastics industry has caused the removal of some important chemicals from fuels, both diesel and gas, over some period of time. Now, I've raced motorcycles for a long time. I have a racing fuel company that I've worked with for most of that time too. They are family owned, and they are the oldest racing fuel company on earth with their history dating back into the late 30's, as I remember. https://www.powermist.com Anyway, Daniel's discussion of how fuels have changed led me back to a period when Power Mist had an additive that could be added to a street gas, specifically, their recommendation was Amoco (now owned and known as BP) premium unleaded. However, buy the early, mid 90's they did say that because of refining and EPA mandates for the recipies of regular and the new at the time oxygenated fuels, there was no longer a big distinction between any fuel refiner's premium unleaded fuel. Daniel responded to my email very quickly, and he agreed that the 2 gallons of vegetable oil with one gallon of unleaded gasoline added to a 40 gallon tank would be good even for winter time use. I had a rear end seal replaced in the E350, and I needed fuel. So, I'm in. I mixed up two gallons of new vegetable oil with one gallon of regular unleaded gasoline, and I topped off my tank this AM. Certainly, the winter cold here will affect my results with some issues of warm up times, my lack of use of the ol' bus even during the colder months. Doesn't get used unless I'm going to go ride on the ice or if I have to transport a whole motorcycle. I drove around doing some things with the mix. I feel that the engine ran very smoothly, and, seat of the pants, I am very, very interested in my long term mileage results. |
Well the vegetable oil will increase lubrication and the "gas" will act like a cetane booster (make the fuel easier to ignite)...so it might work, maybe.
I think you do have to worry about what kind of fuel pump you have when it comes to any changes...but let us know how it goes. |
See the following (abbreviated to stay in post limit ) service bulletin from 2005:
Info - Fuel and Oil Additives - Facts and Myths/Maximizing Fuel Economy #05-00-89-072 - (Oct 24, 2005) 2006 and Prior All GM Cars and Trucks 2003-2006 HUMMER H2 2006 HUMMER H3 2005-2006 Saab 9-7X ... A Statement About Fuel Economy ... The information below contains reasonable and prudent advice for your dealership and the consumer to get the most from every gallon of gas. The information below is presented in two easy to understand sections: • What Not To Do: Engine and Fuel Additives, Alternate Fuels, and "Miracle" Products • What to Do: Maximizing Fuel Economy/Minimizing Costs WHAT NOT TO DO: Engine and Fuel Additives, Alternate Fuels, and "Miracle" Products Various unproven products to improve vehicle fuel economy have been reported ranging from magnets that align molecules to chemical combustion improvers. Most products claiming to provide benefits are based on unsubstantiated claims. Those that do present "scientific" results generally either have too little supporting data to be conclusive, have not conducted experiments in a controlled fashion, or cannot be substantiated by anyone else but the product's manufacturer. The U.S. Federal Trade Commission summarizes results for products tested by the federal government at www.ftc.gov/bcp/conline/pubs/autos/gasave.htm. A review of the list shows that the majority did not work, and for those that showed some effect, the benefit was too small to be cost effective. Harmful Ideas That May Damage Your Vehicle and Increase Emissions One more recent poor idea to improve fuel economy that should not be attempted is to blend either kerosene or diesel fuel into gasoline. Why? Both kerosene and diesel fuel are distillate fuels meant for use in compression ignition engines, not spark ignition engines. They have very low octane and since they are heavier (higher density) than gasoline, they will cause heavy engine deposits and degradation of engine oil. Notice: Never put Kerosene or Diesel Fuel in your Gasoline Engine vehicle. This may result in inconsistent performance and permanent damage to your vehicle that is not covered by your New Vehicle Warranty. Chemicals that are normally used as solvents also should not be used. These include acetone, ketones, and methanol. These solvents can be incompatible with your vehicles rubber or sealing components, and may dissolve the vehicle’s paint finish. In the case of methanol, corrosion of metal parts in the fuel system also may occur. Notice: Never use acetone, ketones, or methanol additives in your vehicle. Some of these solvents may damage or corrode your fuel system. They are also very damaging to the painted surfaces of the vehicle if spilled. WHAT TO DO: Maximizing Fuel Economy/Minimizing Costs The best fuel economy possible is the direct result of proper maintenance and good driving habits. Listed below are GM's recommendations to achieve the best mileage possible. The first group are things to consider for your vehicle, while the second are tips relating to your driving habits. ... • Top Tier Fuels - Some fuel manufacturers provide gasoline advertised asTOP TIER DETERGENT GASOLINE (Chevron, Conoco, Phillips 66, Shell, Entec Stations, MFA , 76, Somerset Oil, QuikTrip, and Kwik Trip in the U.S. and Chevron in Canada. These fuels are preferable when and where available. They help to keep your fuel injectors and intake valves free of deposits. Clean engines provide optimal fuel economy, performance and reduced emissions. When Top Tier fuels are not available, consider a bottle of GM Fuel System treatment PLUS, P/N# 88861011 (in Canada, #88861012), at oil change time which will remove intake system and injector deposits. GM does not recommend any other fuel system cleaner. Important: DO NOT confuse Top Tier Fuels with Higher Octane (Plus/Premium Grade Fuel) commonly sold at most all gas stations. Plus and Premium fuels are required in some high performance GM vehicles. However, they do not necessarily represent higher detergency present in TOP TIER Detergent Gasoline. Important: For additional information regarding Top Tier fuels and availability, please refer to Corporate Bulletin Number 04-06-04-047E for U.S. or 05-06-04-022 for Canada. ... ? Copyright General Motors Corporation. All Rights Reserved |
During summer months, he was running 8 parts sunflower oil to one part gasoline. Pump problems... Well, my girl is going to be twelve model years old with 250k. Two years ago, I started putting used engine oil in my diesel tank quite regularly. I don't make a lot in oil changes, but I don't get anyplace to drop it off, and if I can recycle the oil as a fuel, which I've already paid for, I get a return. There are many pluses and minuses to it, but, on my end, I don't generate any extra cost in storage or transportation. I haven't seen any additional wear, maintenance, smoke, etc. When I use it on the heavy side, she has ran smoother. Potentially, this appears to be related to the fact that used engine oil has more BTU's that diesel fuel. The extra BTU's clean up the nicest RPM of a little below 2000 RPM's, but it's a traditionally lumpy sound from the 7.3 Power Strokes. Some talk of an exhaust drone from 1800 to 2000 RPM's. |
LOL! No, problem. You're just trying to help.
I think you mean 1 part sunflower oil to 8 parts diesel...or about 12%.
As for Pump Problems...it is usually the newer Bosch Style that are finiky. Old Mercedes can run theu about anything. I have a friend with an old Datsun 720 truck that runs used oil also...as long as he doesn't get too oil happy, it works fine. For the newer "high pressure" type systems, you have to make sure the fuel you put in is of the best quality/very clean to protect the injectors and pumps. |
"The magic happens with the unleaded gas/veg oil and diesel. The mixture reforms into a totally new fuel atom chain. With oxygen planted between the carbon/hydrogen. Super fuel as one fuel chemist called it. I always mix my veg fuel for what ever temps it will be ran in. That is to say I can get away with allot less gas in the mix at 90f than I can at 20f. The mixture I ran all summer was 8 parts oil to 1 part gas. This was fine for #2 diesel blending up to 50%.. At this time and temps I am running 5 parts veg oil and 1 part gas. This I have found is safe down to 0f at 100% and good to the same value mixing with diesel." No, it doesn't change the atomic chain, but the opportunities of having pieces of each item, petrol diesel, actual vegetable oil, and gasoline, has a lot of opportunities available that current diesel doesn't have, nor does manufactured bio diesel. So he's found in his experience. Similarly, when one builds a fuel, its a combination of items. It's not just the items, but often an order of the items as they are put together. Specifically, in how I'm using this, think of the three total gallons (one gallon regular unleaded gasoline & two gallons vegetable oil) that I added to my 37 gallon tank as a supplement only at this time to the other 34 gallons. Specifically, I'm doing a 2 & 1 mix to my tank based on his seeing that as safe to -37F. I don't think we'll see that this year, but certainly the potential is there. For me, this is a test. I really recommend going to his site and just browsing a bit. Nothing special, but it has gotten my attention. In the past before I put my used engine oil in my fuel, I had read how others were using used engine oil with gasoline, similarly as a supplement, to their diesel fuel. |
