? about vss for 92 civic vx
does anyone know if the above car has a clean or dirty digital signal to the ecu. The car has the vss plugged into the top of the transaxle (i believe). There is not anything on the hub end of the drive axles, if that helps. THanks
All civics made after 1991 (so 1992 on up) are equipt with an electronic VSS. I'm unsure what the "clean" or "dirty" signal is... but the 1992 VX will send the VSS info in pulses.
