Appreciate the good info. Oil consumption is about one quart between oil changes. How hard/easily do the fuel injectors come out? Do I need any sort of special tool to get them out and/or in?
I also noticed that my spool valve gasket was leaking pretty good so went ahead and replaced it. The little screen was pretty well clogged. Not sure if this has anything to do with the current issues, but sure it will help somewhere. |
There's a good chance the old injector seals will leak after moving things around, so you might want to get 4 sets of seals before messing with them. There's an O-ring that keeps the fuel contained in the rail, a rubber damper on the outside between the injector body and fuel rail, and a rubber seal inserted in the intake manifold port to maintain vacuum. Only the O-ring is really necessary, but the other two wouldn't hurt if you like replacing seals. |
Well, the new Honda OEM tstat seems to be working much better at getting the car up to temp and keeping it there. It does get much hotter than my previous aftermarket tstat was allowing. Gas mileage on the last tank was 42.3 with almost all short distance, city driving which I guess is not too bad.
Will the car run hotter or colder in lean burn mode vs when the Vtec kicks in? Just wondering. |
