To those who have used COROPLAST
I've been looking online at Lowes.com and Homedepot.com and it appears they don't offer sheets of Corrugated Plastic for sale.
Where do I locate this stuff? I'm planning to make my grill block, and rear wheel skirts soon and I keep seeing everyone's mod pics where they've used coroplast.... what is a good source for this stuff? There are some "Custom Sign/Trophy" shops near my area, should I check them out? |
Sign shop is the way to go to get Coroplast, or wait until campaign season is doen and grab the Coroplast signs.
hmm kinda the same idea so im gonan hijack your thread :D
well im plannign to build a hardtop toneau cover(i know i know not as light as a fabric one but 100X more secure meaning i can feel safe leaving expensive items under it) and im going to build the frame out of aluminum or steel angle iron, but im tryign to figure out whats the best top covering, either thin sheetmetal(strongest) aluminum(light but very expensive in large sheets, and would also have to be thick to get equal strength) or a large thicker sheet of plastic, what kind of plastic is strongest thats also the thinnest and cheaper or as cheap as steel? doesnt matter if its clear or not, gonna paint it all anyways has to be somewhat rigid (im making underside support braces but obviously has to span like 1.5 - 2ft gaps.) |
Good luck and let me know where you find it here in the states, it is great stuff. |
My girlfriend's brother-in-law owns a sign shop so that is where I got mine.
I paid $15 for each 4' x 8' sheet. I also got some after campaign season last year for free. |
They also sell Coroplast at plastics supply houses (look up plastics supply in the phone book). This is the same place that sells the 4'x8' sheets of plexiglass, polyethylene, PVC, etc. Since this is where the sign shops buy their Coroplast from, you can usually get it cheaper if you get straight from the source.
I paid $30 for a 4x8 foot sheet at a sign shop. Spent the whole summer retaping duct tape weekly, sometimes daily. If you're gonna use coroplast please consider something more durable than duct tape for fastening.
Next project I bought a sheet of 2.7 mm. lauan plywood for $7.xx at my local hardware store. Also bought a quart of oil-base house primer and a couple cheapo foam brushes. I haven't seen any deterioration and I put that sheet on the front of the car at the end of September. However the finish paint coat has been taking a beating, I have to admit. |
is that shower wall stuff pretty ridid tho? can it withstand at least a foot of snow on it?, hot temps, cold temps, strong enough to resist shattering/cracking if something gets dropped on it? I think I know the stuff ur talkin about but i thought it was too flexable...:( i dunno ill look around. One of my friends dads works at a machineing place and they can get huge sheets but its liek 4X8 or somehitng. there is a plastic supply store down the road i could pop into sometime, but i still dunno whats the bets plastic to use for my situation(ie extreme weather, possible impacts, lotsa weight) |
