Actor Jack Nicholson on traffic lights and solar power
Rick |
Dear Jack,
Shut the engine off at the lights. Dear Jack, Cover your entire estate grounds with photovoltaic panels. You'll be in the shade (or as I prefer to consider, still in the dark), and you'll generate enough electric power in a week to drive an all electric car for two hours. |
Actually that doesn't solve the problem because you had to stop you loose energy - on a short trip each stop can cost you 1-5 mpg off the trip MPG. Solar panels are manufactured with a large amount of energy and usually do not return that amount of energy back in their lifetime plus they are not cheep yet costing about $10.00 per watt of output.
There's a small city in N.C. with perfectly sequenced lights on its main drag. If you drive the correct speed, once you sync up you can roll completely from one end of the city to the other without stopping, despite there being a traffic light on almost every block. Compare that with almost any stretch in Richmond, VA. :( What I read Jack saying is that it's silly to push a conservation agenda yet ignore all the fuel drivers are forced to waste because of poorly or non-sequenced traffic signals. And I included the other quote because of his opinion on big oil's leverage, not the solar power aspect. :) Bottom line, I just thought they were interesting quotes. And even if you don't agree with his views, it's nice to see "normal" drivers (non-hypermilers) paying attention to such things. Unless someone happens to know he hypermiles... which would be even cooler. :thumbup::D Rick |
