VX Shift Light Location
What light indicator in the dash is for the shift light?
None of mine have a white square around an indicator. My car is a California VX so maybe the instrument cluster is completely differnt. I was hoping I could just plop a bulb in and have it work. Do you have a picture?
I found a picture on the internet. I see what you are talking about with the white box around the indicator. I have a bulb location there but it is not wired to anything.
On a side note, it takes a ton of force to pull the plastic around the instrument cluster. |
Mine did not come out gently, the plastic had never been pulled out. It took considerable force just to get it to unclip on any section.
When I said not wired to anything I meant the printed circuit board. It goes to a section that doesn't plug into anything. Couldn't find any extra wires in the dash that might be hanging out but not plugged in. Looks like the circuit needs to somehow connect to another part of the board. If you follow the printed circuit it went to two holes that weren't wired or soldered to anything. Plus the face of the cluster at that indicator would not allow any light to pass through so I'm skipping on having the shift light. |
I have a 1992 California VX, and it doesn't appear to have a shift light either. This is my second VX, and my first was a federal car and it had a shift light, so I know where it is supposed to be.
Perhaps California cars just didn't come with one. |
None of the California VXs came with the shift light, I was trying to add one. I was hoping to get away by just throwing a bulb in an empty bulb holder, no such luck. I figured if Honda was lazy enough to leave the good wide band oxygen sensor in the '92 California VXs, maybe they used the same instrument cluster and just left a bulb out.
