Ever seen a big V8 or V10 diesel idling? Likely using a lot more than .5 gph. Also - it would be the difference between regular idle rate and fuel this device uses, not just regular idle rate.
However, that said, also factor in wear on the vehicle for keeping it running for so long - added savings - longevity in the motor. Electric would be fine just for being at home, not useful most other places for most people. |
I just run a 1000w electric coolant heater myself, unfortunately I can't plug in here at work and we have had about 20 -10F (-23C) days this winter, to darn cold. I have heated seats but still bought a heated jacket and gloves (gerbing). |
There was a test on cars in winter in a recent Tekniikan Maailma magazine in Finland. They found out that Webasto uses about 0.5l/hour and that the fuel consumption was less in a heated engine.. So after about 2.5miles of driving a car that was heated with Webasto started to save fuel.. This was done in 18F degree (-7C) temperature..
I also have a block heater but you cannot use a block heater many places. I like the idea that when I buy a used car with Webasto I can safely assume that it was not subjected to nearly as many cold starts as a car with?ut a Webasto.. |
check this out too https://www.parkingheater.com/en-int/...dvantages.html
